Hi,
Once we had ChapterGrabber, where you loaded your chapters, hit "reset chapter names" and all the chapters would be renamed "Chapter 1", "Chapter 2" to "Chapter n". I have a bunch (a pretty big one) of chapters where the name is the time, god knows what program did extract the chapters like that.
Thing is, ChapterGrabber is no longer maintained and it doesn't work with the newer MKV chapter format it seems (opening an XML throws a "format not yet supported"). It still works with BDs, as those never change ofc.
Any alternatives? We could "brute force" it, mass searching and replacing XML files. I'd have to search for "<ChapterString>nn:nn:nn.nnn</ChapterString>" with "n" being any number and replacing it with "<ChapterString>Chapter n</ChapterString>", "n" there being from 1 to whatever. I know something called regular expressions exists to do the searching, but can you put it to count from 1 for the replacing? Some kind of complex cmd batch maybe?
Results 1 to 1 of 1
Inserting custom chapters into mkvs - sometimes chapter skips "weirdly"
By hayeled in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2019, 10:59 -
how to "normalize" audio?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2018, 16:20 -
Downgrading a "newer" laptop to Windows XP: how new can you get?
By Brad in forum ComputerReplies: 4Last Post: 21st Jul 2015, 10:46 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
What's the alternative to "live streaming": downloading it for later?
By Angus613 in forum Newbie / General discussionsReplies: 11Last Post: 28th Feb 2015, 17:13
